Regarding Meraki AP connectivity from Campus Network
Mohit_Dhanjal
Hi All,
This is regarding new implementation, we are implementing Meraki AP's, that connect with C9300 switch and switch is connected with Checkpoint firewall, do we require NAT configuration to configure from Firewall end, to communicate MR devices with meraki dashboard.
Kindly share your suggestion's.
Regards
Mohit
RaphaelL
The APs need to contact the Meraki Cloud , so yes you will need some NAT to allow that outbound flow.
1 Reply 1
RaphaelL
