Meraki Cloud | Syslog-ng | No log
cypher88
Just browsing
Working on forwarding syslog protocol log message to syslong-ng server.
I've got the configuration file in place but log location /var/log/meraki.log isn't recording any events/alerts.
server selinux is permissions and netstat shows its listention on 514. Meraki reporting syslog is setup correctly using ip and default 514
When i run packet capture using tcpdump, server is receiving messages, but none are being recorded in path defined on the syslog-ng.conf file
Any input is appreciated.
13 Replies 13
KRobert
I've given it a go before but service will not start when using filter f_meraki { facility(meraki); };
Per journal log it seems to get stuck at that configuration.
Inderdeep
Sample configs
source s_ext_udp_15146 {
udp(so_rcvbuf(1073741823) log_fetch_limit(10000) port(15146));
filter f_meraki { facility(local0) };
log {
source(s_ext_udp_15146);
filter(f_meraki);
destination(d_meraki);
destination d_meraki {
file("/logpartition/logs/meraki/$HOST/$YEAR/$MONTH/$DAY/meraki-$YEAR-$MONTH-$DAY"
owner(root) group(adm) perm(0640) dir_perm(0751) dir_group(adm) create_dirs(yes) template("$ISODATE $HOST $MSGHDR$MSGONLY\n"));
Regards/Inder
www.thenetworkdna.com
>port(15146))
It should be using port 500.
BrandonS
514 I think. or it can be changed in Meraki side to match 15146
Oops, @BrandonS is correct.  It should be 514.
Yea, i matched to what was setup on meraki 514... No dice... tail -f /var/log/meraki.log file still shows 0 bytes.. No writes
Is there a host-based firewall running on the server?
iptables inactive
selinux permissive
firewalld.service inactive
BrandonS
That seems to indicate the trouble is server side.  Can you check anything else on the server?
For a sanity check you could use papertrailapp.com it is a free cloud syslog server and pretty quick and easy to configure and test with, if nothing else.
Inderdeep
I hope you configured Syslog with the right configuration as described in Scenario 3 - Reachable via AutoVPN
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Syslog_Server_Overv...
Check this article as well, if you are inline with the configurations
https://snehpatel.com/index.php/2019/09/11/configuring-syslog-in-meraki-device/
Regards/Inder
The first url is for defined host IPs.
I'm sending from meraki cloud dashboard configuration page. Logs are hitting the server, it just not getting logged where I need them to be stored.
The second url you mentioned I keep running into following syntax error when restarting the service on the server.
In that example, the author used "meraki" as a facility. There's no such thing.
Meraki defaults to local0 for the facility and this is not something that can be changed.
