MX CPU / MEM overview in dashboard ?
Hi All !
I'm looking for the graphs displayed in this link
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Device_Utilization
They boast about the ability to see exiting stuff in the summary report ..
I guess I haven't configured my report right, because I can't seem to locate the kind of graph they hint at ..
Any suggestions ?
With Highest Regards
Thyge
Accepted Solutions
Re: MX CPU / MEM overview in dashboard ?
9 REPLIES 9
Organization  》 summary report
Make sure to select a network  with mx.  It should be on the bottom left
Hi ..
The summary report is there, but there is not the graph mentioned ..
The MX is also there, as You can see here:
/ Thyge
And you made  sure the mx  is selected  (top left, networks(s), A single network) of summary report?
@Thygesen the image you're showing us is not the Summary Report. You need to navigate to Organization > Summary reports as @ww said.
I wish I could give double kudos to @jdsilva .  It is critical you have a network selected.  If you have "Organization" selected for the summary report you don't get utilization graphs.
I highly agree !! 2xKudo's from mee too!
WOW That sure did the trick ..
THANX a LOT !!
With highest Regards
Thyge
Thanx a LOT, jdsilva!
That did it! How great, that You are awake, and can guide a rookie like me !
I whish I could give more than one Kudo, since the answer was swift, exact and illustrative, all at the same time ..
Thanx 😀 from the high North (Denmark 😱)
With highest regards
Thyge
Regarding my image (with the ports)
😉Yep, got it .. It was just to show that the network actually had a MX device 🙂
I found the reason (marked very green in the thread) thanx to You all ..
I'm humbled 😉
Thyge
