We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hi All,
Is it possible to configure alerts for a whole organization instead of configuring network wide?
It would be very useful if this was possible.
Thanks,
Pete
Solved! Go to solution.
No. But you're right, it would be usefull.
That's pretty annoying. looks like I'll have to go through all my networks individually and configure the same alerts. Darn!
yeah not the best solution at the moment.
Do "make a wish", surely others did already. But right now I don´t see the point for having this ?
Only thing you can do is to setup a template for future networks, where it is already configured.
You could also use the API to loop through your networks and set it up:
https://developer.cisco.com/meraki/api/#/rest/api-endpoints/alert-settings/update-network-alert-sett...
I can't find the api to do that...does anyone know where that api is?
@RichPekarsky
