How do I sync blacklisted URLs across all organization's MX products?
mike318
I currently manage about 6 MX products. I would love the ability to sync blacklists between all my MX products. Is this functionality that's just hidden or not there?
7 Replies 7
Tung_Nguyen
You can use content filtering->URL blocking.
mike318
I understand how to blacklist URLs, but I don't want to manually enter them into each MX product. I would like to enter them into one network and have it sync to other locations.
Independently managing blacklists for each MX is difficult.
Tung_Nguyen
after you created URL block list in one network then go to Organization->Configuration Sync->choose your Source Network and Target Network then select Content Filtering
mike318
Strange, when I go to Organization > Configuration Sync > Source Network  about 1/3rd of my Networks appear.
EClap5
@mike318Networks that are combined networks won't show up in the drop-down for the Configuration sync tool.  The majority of my networks are combined and the only networks that show up in the tool are my MX-only networks.
Leicams
Just browsing
Hi,  What if you want to sync the Content Filtering settings for Combined networks which is most of my networks.  I do not see Combined networks, only Appliance networks.
Thanks,
Shanec
you cant
