Devices are not sorting according to order - 100+ devices
SMJ
As per the image below when sorting the device by names device #100 is coming after device #10 not after device #99.
I understand this issue with site design.
Is any have any idea about this?
Nash
"Simple" fix is usually to append 0 in front of two digit numbers. Try it in Excel.
It's... relatively easy to do with a script, but if you dunno how to code, could also click through rapidly or make an intern do it.
2 Replies 2
That is correct behaviour.  Specifically the space after AF10 has an ASCII code of 32, while the character in the same spot - "0" - has an ASCII code of 48.
Nothing to do with Meraki.  This is simple, standard and correct sorting alphabetical behaviour.
Nash
