Device End-of-Life (EoL) Visibility Working for anyone?
Is the new "Device End-of-Life (EoL) Visibility" feature working for anyone?
https://community.meraki.com/t5/Feature-Announcements/Device-End-of-Life-EoL-Visibility-now-availabl...
I tried the "new" inventory page in several orgs, and nothing came up for any of them.
22 Replies 22
TyShawn
Yes sir!! I had to click the gear the select EOL / EOS then you'll see the new information.
Mloraditch
Shared 149 and 97 in North America both have it working
I have the column, but I don't see any report or alert banner.
RaphaelL
What licence mode are you using ?
I've only tested it on co-term networks.  Those are the only ones I have with EOS devices in them.
RaphaelL
Correct.
I do see both EOS EOL dates on my orgs with EA 2.0 licences
TyShawn
I'm on EA 2.0 and co-term and both show it for me.
Ryan_Miles
Meraki Employee All-Star
It works on co-term and subscription Orgs because those use the same version of the inventory page. Make sure to use the new version page as already mentioned. Doesn't appear to work in PDL which isn't surprising.
RWelch
Availability: The feature is now GA with a few exclusions. This feature is not available for PDL organizations. Also, this feature is not available for Service Provider organizations since End-of-Life communications are managed directly by service providers.
rhbirkelund
I have it in my Home Lab, although I don't see a banner.
Ryan_Miles
Yeah banners seem to not be enabled yet
If I'm not mistaken, there's already been another discussion about this.
I believe it's only available to those with co-term licensing.
Craieggg
Is anyone seeing the alerting that has been mentioned in the release post? I have devices that are EOS but I am not seeing an alert for it
RaphaelL
As mentionned by Ryan in this thread : Yeah banners seem to not be enabled yet
jimmyt234
Tried a few different Orgs (co-term) and I don't have the columns available on the cog on the new inventory page 😭
jimmyt234
Found the problem - our Orgs are classed as MSP because we have data in the MSP Identification field under Org>Settings, if we remove this value then the EoS/EoL columns become visible.
Does anyone know if this data is surfaced in the API?
jimmyt234
Talking to myself here (again)... but for anyone else wondering it already appears to be in the API, just undocumented on this endpoint: Get Organization Inventory Devices - Meraki Dashboard API v1 - Cisco Meraki Developer Hub
Some examples I have found from different devices that have different eoxStatus:
    "eoxStatus": "endOfSale",
    "endOfSaleAt": "2025-03-28T00:00:00.000000Z",
    "endOfSupportAt": "2030-03-28T00:00:00.000000Z"
    "eoxStatus": "nearEndOfSupport",
    "endOfSaleAt": "2022-07-14T00:00:00.000000Z",
    "endOfSupportAt": "2026-07-21T00:00:00.000000Z"
    "eoxStatus": "endOfSupport",
    "endOfSaleAt": "2015-10-24T00:00:00.000000Z",
    "endOfSupportAt": "2022-10-31T00:00:00.000000Z"
rhbirkelund
If you use the Cisco Support API, you can also lookup Meraki PIDs and check if there is an EoX announcement. The Cisco Support API will even return the recommended replacement SKU.
However, the PID search for Cisco Support API is buggy as h***, and I'm not getting any responses when I give the team feedback.
Come to think of it, perhaps @Oren might have some insight?
Oren
I have the mailer for the team that owns Cisco support API: apix-support@cisco.com.
I'm sure they'd appreciate constructive feedback.
rhbirkelund
And there we have it - I've been sending to supportapis-help@ 😄 Funny it hasn't bounced then.
jimmyt234
I think the last time I looked at this (years ago) we didn't quality for access to the API. I will have another look and see if that has changed. Thank you!
RaphaelL
Closing the loop on this , I'm now able to see the banner :
I might have some cleanup to do.
