CW9178i wifi 7 ap
eager
CW9178i wifi 7 ap
I have a problem for not broadcasting my created SSID ?
regards;
5 Replies 5
Hello
Is the ssid enabled status:enabled?
Does the ap report config up to date?
On the radio settings what bands are assigned?
Is it the ssid using local lan/breakout?
Is it licensed, or in trial mode?
How is it powered, if PoE is it a powerful enough injector/switch?
How do you know it isn't broadcasting?
Are you having a problem or asking a question?
Assuming it's a question, not broadcasting the SSID will prevent users from connecting to it.
If it's a problem, can you tell me what the SSID settings are?
RWelch
When you login to the Meraki dashboard, is the account you are using at least a network admin or organization admin?
Organization -> Configure -> Administrators
Managing Dashboard Administrators and Permissions
Managing Dashboard Administrators and Permissions (Modernized View)
I had this happen yesterday to a customer.  It was the SSID availability.  They had it configured to only operate during certain hours.
https://documentation.meraki.com/MR/Other_Topics/SSID_Availability
