Dashboard License converting to co-termination to per device licensing
Yasiru_SE
Hi community,
Hope you are fine. I am in the process of converting the co-termination in to the per-device licensing. Already License buying process is underway. do you have any experience performing this task?  What are the concerns while doing this process? Thank you
AjitKumar
Hi @Yasiru_SE,
As you know PDL (Per Device Licensing) come with more flexibility of What to renew, Moving Licenses between Orgs. etc.
You may have refereed the following link too
https://documentation.meraki.com/General_Administration/Licensing/Meraki_Licensing
We see PDL as advantage however a few short comings may be
1. PDL cannot be reverted
2. Administration and Management (Keep track of expiry)
otherwise migration process is easy and straight forward. It may take a while to understand the UI and options (happened with me)
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
3 REPLIES 3
AjitKumar
Hi @Yasiru_SE,
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Hi @AjitKumar
Thank you for your reply. I went through the documentation also. I was really helpful. Thank you very much for your time !
Ccnaaws
Meraki's default option for licensing is co-termination. So at the time of deployment, we used this method, but now we want to change the license method and use a per-device license method.
So, is it possible?
