Custom Field for device
lbrown13
is there a way to add a custom field in the MDM device details?
Thanks!
It's included if you do a CSV report, or use the API to gather details. In terms of other reports, I don't know, unfortunately. What are you ultimately wanting to track/report on?
6 Replies 6
BlakeRichardson
Not that I have seen sorry. What are you trying to achieve, is it something that you could use TAGS for?
Unfortunately no, but thank you for the suggestion!
ConnorL
In short, no - this would be a feature request. However, you could use the "notes" section to achieve this though.
Thanks, We were considering using that. do you know if a report can be generated based on the notes field?
Thanks!
We want to track a purchase date.
