Certain Dashboard pages blank or missing elements
Dunky
When logging in using a local dashboard a/c all ok.
However when logging via SSO, the L3 rules section is missing, the Switches-switches and Wireless-Access Points pages are blank.
Plus lots of other issues.
Is this just me or are other seeing the same issues.
Started in the last 10-15mins
TIA
9 Replies 9
ShankarKB
Yes, I am also unable to see the Security & SD-WAN appliance status (showing blank).
Mloraditch
This is not infrequent as of late, recommend opening a case just to get the visibility up, in the meantime try hitting ctrl+f5 to force a full page reload, that sometimes helps, or if the page has new/old versions, switch that if you can see that link.
Dunky
Unfortunately not.....
Dunky
Good to know I'm not the only one, here we go again!!
Perhaps Cisco is trying to compete with AWS/Azure/CloudFlare in taking down any useful services...  At least we'll get extended license time from all of these outages 🤔
RaphaelL
This is really annoying. Also happened to us on nov 24th.
Ctrl+F5 is the "fix"
BlakeRichardson
Try a different browser or see if private/incognito works.
Jblackford
Having the same issue here on the Switch->Switching page. Started about 20 minutes ago.
It came back for me now, no Ctrl+F5 or different browser etc. so I think it was a back end glitch...
