CW9178i wifi 7 ap
eager
CW9178i wifi 7 ap
I have a problem for not broadcasting my created SSID ?
regards;
11 Replies 11
Hello
Is the ssid enabled status:enabled?
Does the ap report config up to date?
On the radio settings what bands are assigned?
Is it the ssid using local lan/breakout?
Is it licensed, or in trial mode?
How is it powered, if PoE is it a powerful enough injector/switch?
How do you know it isn't broadcasting?
eager
thank you , cmr
my power injector is POE80U-560(G)-C-R
I know its old Cisco model, so my doubt is related to this old Cisco model !
That won't work.  It does not output enough power.  You need an 802.3at/bt PoE injector.  Something like MA-INJ-6.
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MA-INJ-6_Meraki_Multigigabit_802....
eager
thank you,
i can see that.
Are you having a problem or asking a question?
Assuming it's a question, not broadcasting the SSID will prevent users from connecting to it.
If it's a problem, can you tell me what the SSID settings are?
RWelch
When you login to the Meraki dashboard, is the account you are using at least a network admin or organization admin?
Organization -> Configure -> Administrators
Managing Dashboard Administrators and Permissions
Managing Dashboard Administrators and Permissions (Modernized View)
eager
thank you,
I had full permission.
I had this happen yesterday to a customer.  It was the SSID availability.  They had it configured to only operate during certain hours.
https://documentation.meraki.com/MR/Other_Topics/SSID_Availability
eager
thank you,
i checked up there,  power transmit is nill in the RF profile.
eager
hi guys , case solved by changing a power injector having 90W.
thank you all.
