Automated reports
BlakeRichardson
Automated reports
I know what I want isn't available via the dashboard but I had hoped that there is something available on the Meraki Marketplace that someone can recommend.
What I need is to have a weekly automated report that lists devices connected to our guest network. ( Using Meraki splash page)
If anyone can suggest a 3rd party solution that would be great.
1 Reply 1
Not quite what you are looking for - but Splash Access is a guest portal system, and it has a lot of integrations.  I'm guessing it might have some kind of system to send a report weekly.
https://www.splashaccess.com/
Otherwise, if you are keen to use the API ... you basically want this:
for client in dashboard.networks.getNetworkClients(net['id'],total_pages='all',timespan=7*86400,vlan=2):
   print(f"\"{client['description']}\" with IP \"{client['ip']}\" made by \"{client['manufacturer']}\" ")
It retrieves all clients in the last 7 days.  There are lots of filters.  This example extracts out all the clients on VLAN2.
