Missing Passthrough Mode MG41E
WilfredoM
I am currently trying to configure a MG41E for passthrough mode. It is in a network bound to a template. In either the template Cellular Gateway settings, or the gateway itself's settings, there isn't an option to set it to passthrough as shown in Meraki's documentation. Any suggestions?
Thank you,
Ryan_Miles
Is it running firmware 3.0? Passthrough was added then. From 3.0 changelog.
New feature highlights
  • IPv6 support for MG21/41/51
  • IP Passthrough support for MG41/51
Ryan_Miles
WilfredoM
It is not. I will update it and give an update. Thank you.
javalins
This should work without issue, just tested.
WilfredoM
Yep, that worked, thank you both!
