- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
License query
Hello Dears, I have a Meraki setup here and I'm looking for a solid answer.
I do have Co-term license mod applied for all devices. and all my license limits and device counts are equal.
so I need to add new MR ( access points ) devices to the network under the co-term mode license. will it work or not? or do I need a new separate license for them?
knowing that I use MR enterprise license mode for all the current MR which already already installed.
Thank you
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
you need to buy a new license for the MR. Which means you need as many MR licenses as you have MR Access Points. Co term date will shift to a later date depending on the amount of years you buy.,
see also
hope this helps
Roger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
see also
hope this helps
Roger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for your prompt response. so also that applies to all Meraki hardware not only MR ? for example MX and MS . Am I correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
right
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Two very small exceptions: A spare HA MX doesn't need a license, and the first five sensors also don't need licenses, as each org has five free MT licenses.
