successful disassociation to SSID
Ab79
User is facing disassociation from the Access-point without roaming, also there is no other Access-Point on this area, so not sure why it is disassociated
RWelch
Disassociation often occurs when the client device has left the AP or potentially gone into a hibernate state (or powered down state) or chosen to roam to another AP.
802.11 Association Process Explained
Try updating the WiFi driver on the machine.
IvanJukic
Meraki Employee All-Star
Hi @Ab79 ,
Looking at the screenshot, the signal strength is excellent! So that doesn't look like the issue here.
What is the user actually reporting? or was this just simply 'noticed' in the Dashboard?
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
