repeater?
George58
repeater?
I was just asked if a Meraki AP could be put in a area of our building that doesn't have switch access and sorta "repeat" the network to that space? I have a spare 2721. What would be my concern, if any?
You can only mesh between Meraki APs, it is not possible with any other AP model.
5 Replies 5
AlexanderN
Meraki Employee All-Star
Meraki mesh is proprietary and only works between Meraki APs, yes.
George58
It would take place in a network of CW91621's and the repeater would also be a CW91621
As long as you are running Meraki firmware you can use mesh.
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/Wireless_Mesh_Networking
AlexanderN
I'm assuming you meant CW9162I-MR, Yes, as long as this is a cloud-managed APs running Meraki firmware the Meraki mesh will work.
