reboot AP MR42
akrammeraki
reboot AP MR42
I would reboot my cisco AP MR42 , by Tools > reboot AP  , but don't be reboot , could you give another way to reboot it by browser ?
Best regards
Network-dad
@akrammeraki I agree with @cmr.  How long did you wait? it often takes 3 to 5 min before a reboot is performed and many times it will not show on the device status... The best way to be sure is have a continues ping going to the AP and watch for it to drop.
Dakota Snow | Network-dad Linkdedin
CMNO | A+ | ECMS2
Check out The Bearded I.T. Dad onThe Bearded I.T. DadThe Bearded I.T. Dad
10 Replies 10
Network-dad
@akrammeraki  Is it connected to a Meraki Switch? you could cycle the port and the will cut POE and reboot the AP...
2020-06-02 08_39_20-Switches - Meraki Dashboard and 1 more page - Work - Microsoft​ Edge.png
CMNO | A+ | ECMS2
akrammeraki
Thank you for your reply , i don't have Meraki switch , what can i do ?
Network-dad
What kind of switch is it connected to? are you able to shutdown the port it is connected to and then turn it back on? are you able to reboot the switch? Also what happens when you push the reboot button in the dashboard. Remember it takes up to 3 minuets for the AP to receive the command to reboot.
CMNO | A+ | ECMS2
akrammeraki
thank you for your help yes,  i am able shutdown the interface connected from switch ,  this action is sufficient to reboot the ap?
when i push rebbot in the dashboard the AP still connected .
@akrammeraki how long did you wait?  The reboot isn't instant and sometimes doesn't even show on the timeline.  If you have someone local, or have a continuous ping to it from the LAN, then you should see it go off and back on.
akrammeraki
thank you for your reply , i will test it and i come back to you
Network-dad
CMNO | A+ | ECMS2
akrammeraki
Network-dad
@akrammeraki Did you ever find out if you were able to get your ap's to reboot?
CMNO | A+ | ECMS2
akrammeraki
It's work thank you
