mr86
combimaster
Just browsing
mr86
Hi ,
i have bought the newest mr 86 meraki
but cannot choose the ma-ant-21 5ghz sector antenna in the dashboard
what default should i use ??
regards combimaster
5 Replies 5
Bruce
The MR86 antenna ports, the two on the top and two on the bottom of the unit, are all dual-band connectors. That is they have both the 2.4GHz and 5GHz antennas connect by a single connector, with the four connectors providing the 4x4 MIMO that the MR86 offers.
As such the MA-ANT-21 isn’t supported - since it’s only a single band antenna - and so you can’t select it.You’ll need 2x MA-ANT-27 for the MR86, these are the dual-band sector antennas, one connects to the top two antenna ports, the other to the bottom two ports.
Inderdeep
 MR86 supports
Four external N-type female antenna connectors
2x N-Type antenna ports are located at the top of the MR86 and 2x are located at the bottom of the MR86.
MR86 features dual band antenna ports thus dual band antennas should be paired with the AP.
https://documentation.meraki.com/MR/Other_Topics/Frequently_Asked_Questions_regarding_Cisco_Meraki_A...
MA-ANT-21 is not certified for MR86 as a Regulatory, it is Certified for use with the MR74, MR84
https://meraki.cisco.com/lib/pdf/meraki_datasheet_antenna_5GHz_sector_13dBi.pdf
Regards/Inder
www.thenetworkdna.com
combimaster
Just browsing
See the following compatible antenna on mr86   the sector ma ant 21 and ma ant 23
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR86_Datasheet
regards
yves
Bruce
@combimaster, I see what you’re stating. It does list the MA-ANT-21 under ordering information, although doesn’t actually state that it’s compatible... I would suggest you bring this up with your local Meraki AM to see if they can assist you.
jmoake
the ANT27 is 12dB gain on the 5Gig which is just less than the 13dB on the antenna you have.  You can select that one and safely be within FCC regs.  You may disable the 2.4 radio since you won't have a 2.4 antenna.
