I have in my network 6 mr33 and 1 mr45. All of them are setup the same, but mr 45 has issue with connecting vlans. native vlan is 1 and is working fine.
Hi @GregK
Hope the MR45 is plugged on a "Trunk" Port with VLAN 3 & 10 allowed.
Check the port config where the other working APs are plugged in. I am betting there is some discrepancy.
You have 6 MR33 and 1 MR45 connected to an MX? If not is there a switch in between the MX and APs?
To verify all MR33s are working with VLAN1 and 10 traffic, but MR45 is only working with VLAN 1 traffic?
Correct.
All 6 Mr33s are working with all vlans ( native,2,3,4,5,6,7,8,9,10). MR45 is working only with native vlans.
there is not switch in the middle. MR45 connect directly to MX.
