how do i fix a mac address from chromecast
jakkrapop
how do i fix a mac address from chromecast with SSID its have a authen to use wifi.
my problem is first i can connect chromecast with wifi but when i re-open chromecast it can't connect wifi anymore. so i cant cast screen.
i can login console meraki.
2 Replies 2
If you want to fix the IP by mac it is necessary to do it in your DHCP server. Who is your DHCP server?
Not sure what your issue is here.
But most problems are;
Your not in the same vlan as the chromecast.
Your ssid is not in bridge mode
You ssid firewall is set to client isolation or Layer3 block local lan.
