- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Clients not able to see SSID
We have multiple new devices (across multiple sites) that are unable to see the relevant SSID for the network. Rebooting the AP, will show the SSID for a short time, then it will disappear again.
Info on phones can be found here
Could anyone point me in the direction of where the problem might be?
Thanks in Advance.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey,
I see a pattern that all these devices are 2.4 GHz only and you have bandsteering on.
It could be an issue if the AP erroneously thinks the client has sent a probe on 5 GHz so it suppresses it's probe responses on 2.4 GHz.
Try disabling bandsteering by just setting it to dual band.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks.
That is what I thought, but just wanted confirmation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Depending on your rf profile setting you may have to edit it there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey @GIdenJoe
Thank you for your answer. It was my case today. Most of mobile phones were disconnected and not displaying the Wifi connection. After allowing the 2.4GHz, it was solved automatically.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It always annoys me that manufacturers are STILL making 2.4Ghz only devices. A dual-band chip set is surely not that much more expensive.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Completely agree.
I know they're cheap devices, but paying the extra for 5Ghz would be worth it.
