Zigbee and IOT devices
edgepro
Deploying a commercial installation requiring IOT door access system using Zigbee. The IOT application is not included in Meraki ecosystem yet. Is there any issue prohibiting this installation from functioning? Any best practice suggestions would be appreciated. TY
6 Replies 6
GreenMan
If the particular Zigbee-based solution is not specifically supported by the infrastructure (in this case Meraki Access Points, presumably) then it basically won't work.
Meraki IoT radios (usually used for Bluetooth) can technicall be repurposed, but this need to be properly developed, which is a pretty involved process, generally involving working with a specific manufacturer and their IoT product(s).
edgepro
Thank you.
It will need its own seperate Zigbee infrastructure and management platform.
edgepro
Thank you
BlakeRichardson
@edgepro I would suggest instead of using bluetooth based IOT using a Wifi based IOT system.
https://security.gallagher.com/Solutions/Access-Control
edgepro
Thank you
