Yellow alert MR42
JED2021
Yellow alert MR42
Does anyone have Guidance for an alert like this?
Radar event pattern detected on channel 64
This AP recorded 2 radar events across 1 channel between Mar 08 09:00 and Mar 09 09:00 PST:
  • Ch. 64: 2 events
DFS event detectedchannel: 64, radio: 1
rhbirkelund
You can do two things;
1) Accept that there is a radar nearby and either a) accept the DFS events, or b) disable DFS channels, or
2) Go over to your local Airport and ask them to politely to stop using their radar.
One of the options are easier than the other.
JED2021
Yes there is an airport very nearby.  I am wondering how to acknowledge the alert.
rhbirkelund
There's no "acknowledgement". They just appear in the Event Log. But if you don't want to see them the event log, you'll have to disable DFS channels.
KarstenI
I like "2", but if you want to go for 1b, instead of disabling all DFS-Channels you can also start with just disabling the channels that give you alarms. This is done in the RF-Profile.
