Wireless uptime
Agus
Wireless uptime
Where i can find wireless uptime menu on meraki dashboard, i already check all menu but can't find that. Appreciate for answer.
Thank you
Agus
Hi, Thanks for link.
6 Replies 6
Make_IT_Simple
Meraki Alumni (Retired)
are you looking for the WAP's uptime or for how long a device was connected to a particular WAP?
Agus
Like that so we know how long access point was connected, so  i can plan for reboot device.
Thank you
Make_IT_Simple
Your WAP's uptime won't be visible on your dashboard, only support can see that. If you need to know any of your Meraki device's uptime, you will need to email or call Meraki support.
Agus
Thank you for the answer, i guess there is menu on dashboard like other access point brand i can see how long access point already connected, so anytime i can reboot for refresh the device.
Thank you for your time and answer.
Inderdeep
The answer is No for any of the device 🙂
https://community.meraki.com/t5/Developers-APIs/Network-device-Uptime/m-p/137003#M5403
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Agus
