Wireless End-of-Support Date
Aknobloch
I have 266 Access Points MR66. The MR66 has an end of support announcement for Jun 9, 2024. My question is: Is the end of support also the end of the Access Point within the Cloud Controller or is it just the end of Meraki support for HW/SW issues or HW replacement?
Does the MR66 continue to work within the Wireless Controller but without Cisco support or software firmware updates or HW replacement?
Now would I recommend continuing to run end of support gear for a long time? No, because it limits your ability to upgrade firmware to address bugs, security vulnerabilities, feature enhancements, etc. And with devices like APs older hardware wasn't as powerful as modern hardware and can also limit your performance, client density, etc.
The official position on this is located here https://meraki.cisco.com/meraki-support/policies/#product-end-of-life-eol-policy
Ryan
5 Replies 5
Ryan_Miles
Yes the AP would continue to connect to dashboard just fine.
Ryan
DarrenOC
Kudos to you @Ryan_Miles for that honest answer.
Ive seen it too many times vendors pushing a full rip and replace post EoS.
Ryan
Thank you @Ryan_Miles
My concern is to understand this point. This way we have time to plan an refresh.
Generally, unsupported devices continue to run - but if you come in one morning and they have all stopped working - you are on your own.
You need to get some budget to replace those APs ASAP.
