Which VLAN is the RADIUS server on?
If VLAN 50 - no need for interVLAN
If other than VLAN50 - yes for interVLAN need.
There is also an option for alternate MGMT interface if needed.
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
