We are trying to setup wireless authentication using certificate alone and configured the SSID access control according to this article
https://documentation.meraki.com/MR/Encryption_and_Authentication/Meraki_Local_Authentication_-_MR_8...
This is the resulting setting for us
We want to use only certificate to authenticate and use the in-built radius server in Meraki AP because we don't have any on-premise infrastructure at all.
Whenever laptop try to connect to the SSID, they get prompted for username and passowrd, even though the certificate has been deployed on the laptop and the connection fails with error Failed authentication EAP Failure.
Why is it prompting user for username and password eventhough we enabled only certificate authentication and disabled password authentication.
Any help or suggestion will be appreciated.
