MT-ANT-27 mounting hardware
iores
which exactly mounting hardware comes with the MR ANT 27? Does it support tilt? If not, does Meraki has any mount kit that supports it?
Ryan_Miles
Meraki Employee All-Star
And here's a quick video. Bolts are loose just to show the movement offered by the mounting bracket.
(view in My Videos)
6 Replies 6
Ryan_Miles
It should come with a couple of pieces that allow for setting vertical/horizontal positioning when mounting. There are some photos around web (or ebay) like this one for example.
iores
how does it work? That part at the bottom right needs to fit into two other parts. The first one is the one at the up right corner, I presume, but I don't see the other part.
Ryan_Miles
(view in My Videos)
iores
I guess all three parts from the second image are included in the package? Because I don't see that plate on the antenna itself. I guess it goes in that empty middle part of the box?
Ryan_Miles
They're included. The plate on the back of the antenna comes pre-installed.
CaNerdIan
What is the actual part number for the included bracket? Meraki seems to have completely forgotten to indicate that in the antenna data sheet, nor did they include any instructions for installation.
