Wifi authentication in k12
zestyorange
I work in IT for a small k12 school district where we have installed Meraki APs and switches and have been enjoying the ease of setup since I'm not a networking guru. My boss wants me to start securing the wifi (yes our district's single SSID is OPEN...) with one of our offices that has 12 people and then grow that to cover the entire district. We use gsuite, but have no directory services like RADIUS or Active Directory, and have a separate VLAN for each of the 5 buildings. Also, we are a Mac district with student Chromebooks.
We are a small district so going with a big expensive enterprise solution will get shot down. And I need some evidence to prove that we need to go one way or another. He wants it to be as seamless as possible for the users and recommended MAC address filtering with their work devices, but I noticed that Meraki doesn't really have a simple MAC address filtering and I'm reading on forums that it's not that secure anyhow.
I have toyed with the different authentication settings and got Meraki to enable Google authentication for 802.1x, but it requires a profile to be installed on all macOS and iOS devices first. I guess I'm looking for the perfect answer that probably doesn't exist. Does anybody have any experience with a setup like this?
Network-dad
@kYutobi do you have any suggestions?
Dakota Snow | Network-dad Linkdedin
CMNO | A+ | ECMS2
Check out The Bearded I.T. Dad onThe Bearded I.T. DadThe Bearded I.T. Dad
Trusted Access has your name written all over it.
https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Trusted_Access_for_S...
You need Meraki Systems manager licences for this.  On your scale, the cost is low.
Splash Access also has a pretty cool system.
https://www.splashaccess.com/splashaccess-education-campus/
They have an integration with Google.  Typically you send students to the portal, they enroll their own device, and you get to control the access.
BlakeRichardson
@zestyorange if you don't have any form of directory service I would recommend Jumpcloud. You could then setup RADIUS authentication using this service.
Your current setup is very insecure, I am surprised your school district allows open networks. Good luck and keep us updated on what you decide to use and how you get on.
