WiFi disconnecting devices
MarcP
tried it in an older Post, but believe no one will recognize 😉
https://community.meraki.com/t5/Wireless-LAN/WiFi-devices-disconnecting-all-the-time/m-p/43042#M6644
I have got the problem, all devices connected to the Guest Wifi are getting disconnected after several minutes / hours.
There is nothing configured you have to re-auth after x-minutes. As I am streaming music, for testing, I do make traffic, so this shouldn´t be the case I´m getting disconnected.
Also tried 5GHz band only, same problem.
Any ideas?
kYutobi
Do you use a splash page? Did you check the splash page frequency? Just wondering it could be that or try to adjust the time a little higher see if it fixes it.
Enthusiast
5 Replies 5
kYutobi
Enthusiast
HodyCrouch
The log entries actually show that the splash page frequency is configured to one hour (3600 seconds).  Look at each line that shows a Splash Authentication.
As suggested by @kYutobi , you should modify the Splash Page Frequency setting.
MarcP
oh my god, this is so embarrassing :S
Can´t remember I set it to 1hour, or even configured it.
Thanks to all.
kYutobi
No problem man. It's these little settings that drive us crazy sometimes.
Thanks to all.
Enthusiast
did you filter this log?
you only have one AP?
did you also try without splash page?
