- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Wi-Fi Access using MAC filtering
Hi Experts,
I want to use MAC filtering to access the wireless network. But I don't have a RADIUS server.
Most of the devices are IoT based
So, please guide me on this matter.
In this case, I will be installing MR76
Solved! Go to solution.
- Labels:
Installation
SSID
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Would still go for "Identity PSK without RADIUS".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Don't see how you'd achieve this without a NAC/Radius server? You could look at doing this with IPSK with Radius using Freeradius (open source).
https://documentation.meraki.com/MR/Encryption_and_Authentication/IPSK_with_RADIUS_Authentication
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As mentioned, RADIUS is needed for that. But as MAC-filtering will not add any security benefit, I would go for "Identity PSK without RADIUS" to give different groups of IoT devices different PSKs and group-policies.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for your reply.
I want to give some details of my ongoing deployment.
We use one subnet for all wired and wireless networks so all users including IoT are in one subnet.
All IoT devices use only a wireless network and other users connected on the wire.
So please advise, how can I implement these policies?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@npnitin that isn't great from a security point of view IoT devices are notoriously (insert favourite expletive) in terms of updates and general security so I'd look to change to a different setup where you use VLANs and can secure IoT devices off from the rest of the network.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@npnitin Meraki doesn't support the use of MAC filtering without using Radius. Radius is a requirement, if you don't have a radius server your options are set one up or choose a different authentication method.
