That's from the Product Catalog and it has several errors that need correcting on multiple models.
As @GreenMan stated all Meraki APs use the same licenses and therefore should be the same cost.
From what I see the only one that's correct (of the Wi-Fi 6E models) is the MR57.
MR57 | 1 | $201.00 | $402.00 |
| 3 | $452.00 | $904.00 |
| 5 | $753.00 | $1,506.00 |
| 7 | $1,054.00 | - |
I'll check with Marketing to see why there appear to be errors on the site.
UPDATE - Marketing is aware and has tickets open to fix the errors.
Ryan / Meraki Solutions Engineer If you found this post helpful, please give it
Kudos. If my answer solves your problem please click
Accept as Solution so others can benefit from it.
