- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
While Claiming MR-42 AP in my current Network getting error NBAR error
Hi Team,
I have Mr-46 AP connected in my current network, while Claiming different model(Mr-42) in same Network, I am getting error "Can not add MR42 device to a network running NBAR.
Solution that i have checked if i want to add this AP in Current network, i need to disable Network Analysis.
Can i create New Network for same Site, and Broadcast same SSID in this new Network, Will it works.
Kindly Suggest.
Regards
Mohit Dhanjal
Solved! Go to solution.
- Labels:
Installation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That could work for ssids using bridge mode. But maybe auto rf settings wont be ideal and you need to make sure to not use rogue AP blocking/ or whitelist them
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you use nbar? You could also disable Network Analysis. Then add the AP. Then enable network analysis. It will then use the "older" meraki categories
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
NBAR is enabled automatically.
After disable Network Analysis, if i add the same, do i face any issue like Configuration issue and traffic analysis issue.
Regards
Mohit
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Mohit_Dhanjal : Just disable and try !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Tried, Same is working.
But my Customer want to Create n new Network for incompatible access point in same Client Site.
If i create new network and claim these AP in new network with same SSID and configuration and with Same PSK, will it work or create an issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I suspect the firmware on the MR46 is too old. Create a new temporary network, add the MR46, make sure the firmware is updated to at least "stable", and then try moving it to the original network.
