What is the coverage area for MERAKI MR45
Bertontangu
Hey
I need the coverage area for Meraki MR45
CptnCrnch
5 Replies 5
CptnCrnch
DarrenOC
hi @Bertontangu
datasheet for MR45 below, coverage etc will depend on the environment into which they’re going
https://meraki.cisco.com/wp-content/uploads/2020/05/meraki_datasheet_MR45.pdf
Claes_Karlsson
Hey,
The coverage will depend on other radio sending devices on the channels/band, how the physical environment is like what kind of walls, any obstacles etc. It's almost more important to have devices capable of sending back traffic to the accesspoint rather then the accesspoint itself sending out radio waves.
Wifi planning and design is a huge topic that we can discuss in hours.
Here are the datasheet for MR45:
Look at the Antenna section, 5.4 dBi gain at 2.4 GHz and 6 dBi gain at 5 GHz.
I personally wouldn't place any client farther than 15 meters from the accesspoint, but the accesspoint itself would be capable of sending out farther than that.
/CK
Bertontangu
Ah ok
The environement influent highly for the installation and i can decide the distance enter two AP.
I normally allow for a 15m radius circle in open air for good performance.
