MR18 was on port 33 of Cisco switch and getting 60 Mbps throughput
MR33 was on port 21 of the same switch and getting 260 Mbps throughput, both ports configured the same way
All our MR18’s in different buildings and cities are getting 60MBps and MR33’s get around 260 Mbps
Switched ports 21 and 33 and rebooted both AP’s, MR18 still getting 60 Mbps and MR33 still getting 260 Mbps so not a switch issue but is a Meraki MR18 issue.
Meraki tech support open a case for this and after 6 weeks decided it was normal behaviour and expecte throughput for the MR18, even though they had my run iperf rtests and update merakis and many other test sduring the 6 weeks, so if it was expected how could they not know that 6 weeks ago?
From the web
Dual enterprise class 802.11n radios, up to 600 Mbps
The MR18 features two powerful radios and advanced RF design for
enhanced receive sensitivity. Combined with 802.11n technologies
including 2x2 MIMO and transmit beamforming, the MR18 delivers
data rates of up to 600 Mbps and enhanced coverage, meaning
fewer access points are required for a given deployment. In addition,
the MR18 uses band steering to automatically serve 5 GHz-capable
clients with the 5 GHz radio, maximizing capacity in the 2.4 GHz
range for older 802.11b/g and 2.4 GHz-only clients
