What are the correct operating temperatures for MR (E) model APs
Erick_Wifidrs
With most model APs on the market. APs that have external connections have a wider range of operating temperature than similar models with internal antennas. (More inside components more heat ...)
On the Meraki product datasheets for most (E) model APs, the operating temperature is the same as the (I) model counterparts.
example : https://meraki.cisco.com/lib/pdf/meraki_datasheet_MR53E.pdf
                https://meraki.cisco.com/product-collateral/mr53-datasheet/?file
This appears to be an error. Does anyone know the actual operating temperature?
2 Replies 2
BlakeRichardson
@Erick_Wifidrs  Hmm zero degrees C doesn't seem right however that same information is also displayed here.
https://documentation.meraki.com/MR/Installation_Guides/MR53E_Installation_Guide
Will see if I can help get you a firm answer.
Erick_Wifidrs
No it does not. Help is greatly appreciated on this subject.
