Godd Morning,
I'm having a weird behavior in the Meraki Dasboard configurint Manual channles and transmit power in radio settings. Previously, I could configure the channels manually and then the transmit power with the edit bulk options. But now, when I configure the second options, the first one came back to auto. For example, if I configure the channels manually in channel 6, it takes the config, but then when set the transmit power static to, let's say 14dBm, it configure the transmit power but then the channel came back to auto. And viceversa...
I had done this before without problem, but now I can't.
The work around that I found was entering in the old version of the Radio Settings page and change the parameters one AP at time...
Thanks in advance for your attention
Regards
Hector Laya
