Unavailable reports in MR
GuiBertinato
Hi, i want to create a unavaliable MR's report about the time that all MR's became unavaliable in the month, then calculate the percentage that it became unavaliable during the month, is there any way i can do that by API?
Thank you!
Mloraditch
https://developer.cisco.com/meraki/api-v1/get-organization-devices-availabilities-change-history/
That API I think is what you need to get the data and then make the calculations. At least it's the closest possible solution I can find.
1 Reply 1
Mloraditch
