Unable to register new MR42 AP
Vinit
I am trying to add the new MR42 AP but unable to add based on below error ,
"Cannot add an IMDA(SG) regulatory domain to a WPC(IN) regulatory domain. Add to a new Network or contact Meraki Support"
Trying to register the above AP to the india network but it is showing as "SG" when tried to claim due to which i am unbale to register the AP with the said error.
So, how can i change the country/region for the said AP (MR42) from SG to IN
DarrenOC
Hi @Vinit , sounds like you've purchased the wrong AP for your Domain/Region.
Are you able to go back to your Meraki partner in-country and ask them to RMA and replace with the correct one?
antonis_sp
Create a new wireless network with default settings (temporary, can be deleted later) and change Network-wide > Configure > General > Country/Region to (IN)
Add AP to this network (and wait until it comes online)
When AP is online go to Network-wide > Configure > General > Country/Region again and there should be a mismatch error, allowing you to change the AP domain, after you acknowledge the change.
more info -> MR_Wireless_Regulatory_Domains
After that is complete, you can move the AP to the network you want. (that works with APs from US, that I add to EU networks, should probably work for your case as well).
Vinit
Hi Antonis,
trying to follow the above steps but the option to change the Country/Region is hidden and unable to modify the same and can only change the "Local time zone" which i modified from US to India time zone.
Kindly suggest.
Vinit
Hi Antonis,
Issue is now resolved as i waited for the AP to come online post which i was able to modify the Country/Region and moved the AP to required network.
Thank you once again for the assistance.Appreciate that !!!
