It will switch to a non region specific SKU on Nov 30. So, it will just be MA-INJ-4. And you'd then add the region specific power cord. In your case that would be MA-PWR-CORD-EU.
You should be able to still order the MA-INJ-4-EU until Nov 30.
Ryan / Meraki Solutions Engineer If you found this post helpful, please give it
Kudos. If my answer solves your problem please click
Accept as Solution so others can benefit from it.
