Unable to connect to MR33 since changing from iPhone 8 to iPhone SE3.
After connecting, it happen "unknown reason" and "disassociated because client interface was disable" at event log.
- It not had any problems until now.
- AP is MR33.
- It appears to be trying to connect to various APs as a maybe handover(from event log).
- I've tried change SSID setting from band steering to dual band, but it didn't help.
- MR firmware version is 27.7.1. I know this one is old, but it's not easy to change firmware because customer site.
Do you know any Wi-Fi connection issues related to the iPhone SE3?
Are there any configuration changes that would be effective? Maybe version up firmware is best?
