Time Synchronization
akakapp
Is there documentation I can download explaining how Meraki synchronizes time across a network?  I need this for PCI.
RWelch
The Upstream Firewall Rules for Cloud Connectivity references NTP resolution as follows:
Screenshot 2024-10-14 at 11.52.13.pnghttps://documentation.meraki.com/General_Administration/Other_Topics/Upstream_Firewall_Rules_for_Clo...
RaphaelL
I though I read somewhere that devices running recent firmware are no longer using udp 123 for ntp. They are doing ntp inside next-tunnel. Can't find info about it tho.
RWelch
Possibly so - another location to reference is HELP > Firewall Info which shows UDP 123.
I don't see NTP queries being made from Meraki devices over the public Internet - so I believe this is correct.
About 2 weeks ago I had a customers AnyConnect SAML configuration break because of time synchronisation.  The time it was syncing from the Meraki NTP servers was around 100s out.  SAML allows for a time error of 30s.
Support wasn't able actually to do anything.  I was hoping they could point it at some different NTP servers, but nope.  It can only use the internal Meraki time servers.
After enough reboots I guess it locked onto a different internal NTP server with the correct time.
That is the only time issue I have ever run into.
