Dear Meraki Support Team,
I am currently using three Meraki access points in our deployment: two MR53 units and one MR56. As Vietnam has officially approved the use of the 6GHz band for WiFi 6E, I would like to enable this functionality. However, I have not been able to activate or detect the 6GHz band on these devices.
Could you please advise whether the MR53 and MR56 models support WiFi 6E in Vietnam? If they do not support it, do you have recommendations for Meraki models that are compatible with 6GHz in this region?
Additionally, if firmware updates or configuration changes are required to enable 6GHz operation, I would appreciate your guidance.
Thank you very much for your support
