Meraki Access Point is Restarting constanly
Mike76
I have a one Access point that is restarting Daily.
2 Replies 2
Brash
How are you powering the AP?
If PoE, do you see any logs indicating switch port transitions? Do you have many other devices drawing power off the same switch?
If by external power adapter or PoE injector, have you tried swapping them out?
Raise a case with support to check it.
Is it restarting at the same time, or different times?
