Sponsored guests reporting and who approved for WiFi
DPJW
Is there possible for Meraki Dashboard to show sponsor guests and who approved the guests?
8 Replies 8
Yes, It is. Refer the documentation.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Sponsored_Guest
Shubh3738
@DPJW Go to network wide then configure users. After that check authorized by.
DPJW
Hi @Shubh3738 , I'm not using Meraki Authentication. Just purely open Wifi with sponsored guest login. Hence, when I navigate to network wide and then configure users, I don't see anything
@DPJW
Check the documentation. I think that it will help you.
DPJW
Hi @alemabrahao , I had reviewed the documentation. However, there is no anything that referring to what I need. My main intention is to have a list that shows all the sponsors that approved the guest, for audit purpose. Does Meraki Dashboard have this feature?
You can only see it in the details of the clients page.
DPJW
Yea, this is what I found out as well. Unfortunately, Meraki yet to have the options to generate the list of sponsors that authorized the guest.
BlakeRichardson
You might be able to see that info by going to Wireless > Splash Logins although I don't have a network configured that way so can't tell for sure.
