Sponsored Guest Login Broken??
Dunky
I have noticed that under Wireless>Access Control, for all SSIDs that have Splash page set to Sponsored Guest Login, the Sponsor email domains, duration and session length have all  been lost.
Is this a global thing that Meraki are going to correct or do we need to correct these on every single SSID across all our networks?
Dunky
I raised a call with Meraki support as suggested.
If you click on New version on the page in the top right, the new version of the page does actually show the settings - they are just not shown on the original page.
BrandonS
That doesn't sound good.  I would ask Meraki support if they are aware and check your change log to make sure it was not done by someone inadvertently.
Dunky
@BrandonS Its happened to every SSID that has sponsored guest login, in every network.  Also across multiple unrelated organizations in different dashboards.
I'll raise a call with support as you suggest, thanks.
Dunky
