Setting up HP Envy for wireless printing
dmcritchley
I have a small network of MR67 router connected to fibre broadband service; a MS120 8 port switch and some APs (2 x MR36 and 2 Ubiquiti ones).
I have an HP Envy printer connected to one of the APs which I would like to set up so anyone can wirelessly print from anywhere on the network. The device is visible from the Meraki Dashboard so is set up for wireless printing which you can only do if you directly connect to it vs through the network. What do I need to set up in the Meraki Dashboard to allow this wireless printing from anywhere?   fixed by changing from NAT to Bridge mode
Also in terms of general security set up what should I do on the MR67 and MS120 to protect them or is the AP security sufficient to prevent intrusion?
Inderdeep
Great, so it is fixed !
Regards
Inderdeep Singh
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
1 Reply 1
Inderdeep
Regards
Inderdeep Singh
