Set Up Google TV on a Meraki WLAN
KSVSachsen
we are using Meraki MR-32 and 33 behidn MX-84 to provide some WLANs with. I'm not possible to get a Google TV 4K Working. When it joins the WLAN it says that  it has no connection to the internet.
Can someone, who has a working google tv, proivde me the correct settings/rules.
best regards
Robert
Have you tested connecting another device to the same WLAN to validate that it is not a network configuration problem?
What type of authentication are you using. Do you have any firewall rule that could be blocking the communication?
Sander
Yeah check DHCP config, DNS server and FW settings (in wifi part and in MX part), it looks like your wifi connects but your IP traffic gets blocked. Does this SSID work for other devices. What authentication do you use on the SSID?
TBHPTL
Google TV or a Google Chromecast with Google TV... Also Android can only have one connection active at time if it has an Ethernet port unplug it.
