SSID with Two Gateways
Aztec_Ninja
I arrived at site today with an MX68 and MR33. There is an issue with a SSID which is assigning the endpoints two Gateways. One Gateway IP is valid and there is erroneous. Traffic is flowing correctly to the Internet but services on the LAN like printing are not. The SSID in question was setup with Layer 3 Roaming and VLAN Tagging. The tag is set to the correct VLAN with DHCP enabled. However there is only a single MR. There are no errors from the MX or AP, routing table looks good. Firmware: MX 18.107.2 MR 29.7.1 Any ideas?
Aztec_Ninja
The issue was resolved by removing the Block LAN on the wireless firewall and traffic shaping.  The double gateways really through me off.
5 Replies 5
Look, I don't think that's possible. Are you sure the client does not have a static IP configured?
Why are you using L3 roaming?
Aztec_Ninja
I am taking over network so not 100% sure why, maybe they were future proofing.  I am going to test with a new SSID to confirm if it behaves the same way.
What other network equipment is in use at the site?
Aztec_Ninja
We are using the MX and MR on Internal network, with a ISP Router at the edge.
Aztec_Ninja
